Vans RV-8 G-JBTR
Date:  12-3-2010
Number of Hours:  0.00
Brief Description:  Mixture Bracket 1
Problem. When looking to install the Vans IO-360 Throttle/Mixture Kit it became obvious that the Superior Cold Air Induction Sump and its forward plug would interfere with the VA-164 Mixture Bracket- also the mixture arm provided by Aero Sport Power was a straight one (red circle).
After much searching I came across Jason Beavers excellent website and he solved the problem (Photo 2) by:
1. Reducing the width of the VA-164 Mixture bracket
2, Inserting an AN932-05D Plug (may have to file down and re-paint) link for UK builders
3. You need a short offset mixture arm to clear the Sky Tek light weight starter - the required part number for the Silver Hawk EX-5VA1 Fuel Injection Servo mixture arm is 2521287
Mixture bracket problem
Recommended solution
