Vans RV-8 G-JBTR
RV-8 Build Log
Fuel and Brake Pipes 2
The 1/4" aluminium brake pipes were quite straight forward. I used 1/4" ID clear plastic tube to protect both the vent and brake pipes from chafing.
Pressure test all the fittings BEFORE you install them - I have to repeat this top tip for the important message to get through :-)
1/4"brake pipes
Left Gear Tower
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
