Vans RV-8 G-JBTR
RV-8 Build Log
T 405 Angle
Who needs to go to the gym when you can cut out the T-405 angle?
Checkout this
animation of the process
When positioning the rivets I ensured that the AN924-6D nut would not interfere with the AN470 rivet heads and also just enough room to have the 13/16" socket as this has to be torqued.
From this ..to this
AN924-6D
13/16 or 22mm socket
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
