Vans RV-8 G-JBTR
RV-8 Build Log
Elevator Trim Servo
The elevator trim servo is a very tight squeeze and the things I had to do to get it to fit were:
1. Extend the opening for the servo arm slot (this is mentioned on the drawing - Note 6 DWG 4)
2. Filed the nut plate edges (image 3 shows the one remaining one to be filed)
Drilled hole
Check for interference
filed nut plate edges
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
