The temperature on the P-Mags are slightly critical and they also need a cooling blast tube so I thought it might be a good idea to monitor the temperatures with spot labels.
Whilst at it I put one on the Odyssey battery and EFIS Data Acquisition Unit to see if it will need a jacket to insulate it from the FWF heat.
I bought them in the UK from OMEGA part number 4A-170 these have spots for 77 / 82 / 88 / 93 deg C which are good for the P-Mags (limit 88 deg C) and the Odyssey Battery (80 deg C)
As of Dec 2015 One spot (77C) on the P-Mags none on my battery or EFIS data acquisition unit located on the firewall.
