Brief Description: Baffles 3 - Lower Cowl/Forward Baffle Fit
First remove the prop spinner/backplate.
I removed 1/4" from the outboard side of the inlet ramp tapered to the bend point of the side baffles. This was spot on so maybe shoud have trimmed 1/8" as a starter.
I removed 1/2" from the side ramps and the forward edge of the inlet ramps to get the lower cowl into position.
