Vans RV-8 G-JBTR
Date:  6-26-2011
Number of Hours:  0.00
Manual Reference:  Ch 12
Brief Description:  Oil Door 2
Oil Door 1
The door flange is to be perfectly blunt - crap.
So I trimmed the door with tin snips and then sanded it square on the cowl sanding tool so that it had a reasonable fit.
Drilled and bonded the hinge to the cowl and glassed around the rear of the door flange as I had to sand it quite thin to get the door to lay reasonably flush (dark corners).
I then sealed the door edges with shiny parcel tape and faired in the door with mayo epoxy. I will uses more filler when I know exactly how much needs to be applied.
Continued/
Hidden Hinge - Hinge bonded
Door faired in
Door faired in
