i got the spinner support on, which was a PITA. by the time i was done i had hand cramps from working the in the tight space. then i worked on getting the bottom cowl fitted up. i needed to open up the gear leg holes a little, then i got out the strap to hold it in place and tried to set a gap at the spinner. i'm going to go for 1/4 inch gap, which i hope is enough. i can always open that up a little if it's to tight.
