today i riveted the foreward stucture in finally. i reinstalled the plastic blocks and then i put the fwd skin on. next i forced the pivot points for the canopy into the openning in the plastic blocks (it was a very tight fit). once it was all together, i looked inside to see why it wasn't sitting down right. looks like it is hitting on the center section. other then that it looks like it will fit ok. more to follow once i open up the slot.
