i'm just trying to clear up some of the things that i've been putting off. did the doubler plates for the vhf and the transponder antennas. put the cockpit together, more or less. i still need to take some of it back out, but i need to cut the heat control cable to length, so i sort of needed the instrument panel in to see how much to cut. i put the center console in to check the cable throws, looks like this will be a lot of work.
