Josephs Web Site
Date:  2-21-2011
Number of Hours:  5.00
Brief Description:  big day #1
so today i had off for presidents day, had to make the best of it. i removed the tail feathers to start. the project looks so naked with out them. i put the adel clamp on the rudder sleeve finally. then i started on the engine mount. lots of tape and measuring and trimming later, it was mounted. this was not all that hard, thanks to duct tape. i marked the flanges on the lower firewall where the gear will come out and trimed them, then duct taped it back in place. i started with a 1/4" drill, then a bit bigger, the a 3/8'. once i had the top right one drilled to full size, i put the bolt in and moved to the top left. from there it was easy, and it's even level.
