got it licked today on the fuel lines (i think). i got the purge valve return line in and the i put the fuel valve and boost pump in and it all fits. yeah. i still need to take it all apart and put it back together with fuel lube on all the fittings, but that should be relitively easy. then i started sweating the panel, mostly where the mid supports are in respect to where my stuff will be. need to research moving both support ribs it looks like.
