i got an early start today. first i got the aileron installed and rigged. then i put the flap into position and drilled the hinge. i cut out a lobe to do the center pin install on this side also. once it was riveted in place i installed the flap. i also put the anchor nuts on the access panels and installed those. so i guess i can call the wings complete.
