i was able to use solid rivets on the outboard rib and squeeze them with the pnuematic squeezer. then i did some research and discovered that most people use blind rivets for the rest of the ribs, and that vans even approves of it. so i put in a couple of rows of blind rivets, using the lp 4-3's. when i got to the areas that are thicker i didn't think they would work. so i'll get some cherrymax at work tomorrow and finish up with them. anyway, it was to early to quit, so i got the flaps clecoed up. i even bent the left flap angle, which was a pain. i also made the spacers and the angle. reading other peoples log it seems that a lot of people have to use a shim on the gap between the lower skin and the end of the rib, but mine are fine, no gap to speak of.
