i put in a long nights work, and i got a lot done. i finished fitting the skeleton to the skin and final drilled everything. i think the thing that took the longest was countersinking the holes for 709. i spent quite a while on this, didn't want to mess it up. in the end i used the drill press and just the bit and pretty much just touched the skin. i fit checked it after every little touch, and the countersinks came out great. i then took it all apart and started deburring and prepping for primer. i'll prime tomorrow for the right side.
