as i was thinking about quiting for the day, i realized i had made a mistake. i needed to run the wire for the fuel sender thru the inboard rib first, so i ended up cutting the bnc fitting off and i'll resolder it on when i put the inboard rib on tomorrow. i got things lined up for the last to ribs to go on tomorrow, and i safety wired the flop tube to the fitting too.
