after work today, the first thing i did was establish a fuselage center line. from there i measured out and established an offset center line thru the center of the wheel. i had to build up some mass where the rear pant attaches to gear, so i laid up three layers of glass at the spot i had marked. once that was cured, i put the rear pant on and made sure the rear tail was aligned with the fuselage center line, and drilled the pant to braces. the pants are aligned with the fuselage, but centered on the wheel (which is canted). then i pulled the rear pant off and put the front pant on so they match up, and drilled the holes.
