i decided to take the opportunity today to clean the hangar and straigten up a bit. when i got done i had 2 workbenches clear again. i put the engine on the build up stand ( it will be easier to work with there for the rest of the build). then i made the brake lines. this was acually pretty fun for a change. i hate working with tubing, but this thin stuff is so easy to shape. i have to order the fittings, so i made a list of all the fittings i'll need FWF and put in an order. i also laid out the position for the firewall mounted oil cooler.
