Josephs Web Site
Date:  1-30-2011
Number of Hours:  4.50
Brief Description:  canopy frame
worked on the tip up frame today. after putting it on and taking it off about 30 times, it finally fits. i riveted the frame after countersinking, then set the gap and drilled the hinges. at the end of the day i put the frame back on and put the skin on (to see if it would work). i have some minor catching in the center that i will have to fix, but not to bad.
