after the first wing went on, i fixed the small issues we had with the right wing on the left one, and it went on i about a quarter of the time. we then pulled the right wing back off, and corrected the issues with it (the rear spar brackets were too long) and put it back on. i decided to check to see how level it was, and you can see what i got. the fore aft need to be adjusted, but it's in there too. the last thing i did was hang plumb bobs off the leading edges to check sweep. it looks pretty good, but tomorrow i'll check for square some more, then on to the incidence. sure looks a lot more like a plane now.
