today i was able to level the fuselage, and get the aft deck riveted on. this was actually pretty easy for me, everything just kind of fell into place. i had a very slight twist at first, but as soon as i clamped the rear deck into place and made sure i had the same edge distance on both sides, it was perfectly level. so i drilled it on and riveted it. i still have to do the rivets in the rear section, i wanted to see if those get done now or in assembly with the horizontal stab (they get done now it turns out).
