Jacks Web Site
RV-7A
Instrument Panel
10-11-2011
Installed throttle control
Mounted the throttle cable to the throttle using the supplied fire sleeve and brackets. The firesleeve needs to be properly secured. The cable is run through a rubber grommet in the firewall and will be further secured with a firewall shield.
Throttle cable through firewall
Firesleeve added to cable end
Attached rod end to throttle
RV-7A Home
2689
436
Firewall forward
103
332
696
Gear fairings
Instrument Panel
78
419
Shop Setup
552
