Brief Description: Built Fuse Panel Under Pilot Panel
Since I decided to use fuses instead of circuit brakers in the electrical system, I needed to find a convenient place to mount all the fuse blocks. I want to have all of the blocks in a convenient place to access. I built a panel that is hinged in the rear and attached in the front with two flush mounted latches. The fuse blocks are mounted on the inside surface. The panel is cut to fit around the ventilation system. In operation, the panel will be accessible from the pilot's seat for fuse inspection and replacement.
