Vetterman's provides the exhaust system as part of the firewall forward kit. It includes everything that is needed for the exhaust installation. The pipes are numbered so that you can figure out which sections go together. I found it very easy to figure out how the pipes should be assembled. The pipes are made of stainless steel and are suprisingly light weight. I bolted up the pipes in one evening.
