Trying to determine shere to mount the fuel flow sensor. The unit provided with the Dynon is an EI red cube. They recommend mounting the unit with the wires pointing up, but the exit fuel line must also be directed up and should rise from one to two inches to keep bubbles out of the line. The sensor could be mounted on the engine mount. There is enough length in the flexible hose to cut it and add connectors to mate it to the cube. The only concern I have is whether this is a good location.
