Brief Description: Further measurements for snorkel fit
I set up the engine to measure the dimensions needed for the snorkel. I decided that I needed to make a fiberglass transition between the two halves. I aligned the snorkel up to prepare for another cut. I drew a line about 1 1/4" away from the first cut. I decided to use rigid foam to create a form for the transition.
