Laced up the wiring performed thus far. Routed the wiring up to the area under the pilot seat. In order to determine whether I make a collapible harness inside the control stick, I created a test harnes with 13 wires. I wrapped the wires around a mandrel and laced them up. The result was a harness that was flexible and collapsible inside the tube; suitable for hiding a connector in the tube.
