Jacks Web Site
Date:  5-19-2012
Number of Hours:  3.00
Manual Reference:  ?
Brief Description:  Radio and electrical checkout
So I started to do electrical checkout of all the systems I could. All the lighting worked fine. With the plane outside, the GPS's were all able to lock on to satelites. I tested the Comm radios with a hand held that Kay carried around for some distance. It's hard to tell what the reception will be in actual operation without getting into the air. The SL30 Nav radio was able to pickup the Rocket VOR if I turned the squelch all the way down and turned the Skyview system off. Seems as though there is some RFI generated by the Skyview system. I also discovered that the audio did not work on my 7" screen. I sent this unit back to Dynon for repair and got the RFI filters. Filters are in place and the VOR seems to work better, but is not completely unaffected by the Skyview.
N915JK sees daylight
Proud owner/builder
Proud owner/builder
Checking out radios
Checking out radios
