Spent a day remounting the terminal blocks for the joy stick controls onto the spar web. Also, removed the lockout relays entirely because they are no longer needed. I added diodes into the control lines to prevent any inadvertant control from the unselected stick. This required adding 9 diodes into each stick grip. These were just spliced into the existing leads. I rerouted all the wires into the appropriate terminal block here.
