Finally found sufficiently small plastic T's for finishing off the Manifold Pressure plumbing. Van's store had them all the time. Used three sizes of plastic tubing to mate to the Manifold pressure sensor, the two Lightspeed Engineering ignition modules and back to the port mounted on the firewall. Used safety wire to clamp the tubing to the attach points.
