Brief Description: Fabricated mounting for avionics fan
Added an angle bracket to the antenna shelf backing plate in order to mount the avionics fan. The fan will provide forced cooling air to the Garmin 430 and the ofther avionics bays. There are 6 screws that mount the fan to the rib on the side and the backing plate in the front. Nutplates are used throughtout.
