Soldered the wires for the copilot headsets and mic into the front panel connectors. Mounted a barrier strip o the side rail in order to terminate the copilot map light into the dimmer circuit. Applied terminals to the map light wires and completed the assembly. Similar wiring was done on the pilot side.
