Spent several hours lacing cables around the cabin. There are cable runs across the top of the firewall for firewall components, grounds, and signals that go to the EMS module. There is a cable run past the ignition system, a run along the first bulkhead for power distrubution and lighting circuits, and a run along the panel for panel wiring. I've tried to isolate the measurement lines from the computer serial lines as much as possible. There are no antenna runs in any of this. They will be run separately on their own paths, isolated from each other as much as possible.
