Started with the left wint. Drilled out the holes in the aileron brackets to size. Attached the aileron to the back of the wing. Made the jig to hold the aileron in the neutral position. Installed the pushrod between the bell crank and the aileron bracket. Adjusted and set the length of the pushrod.
