Brief Description: Mounted fuel pump overflow line
The fuel pump has an overflow port that needs to have a hose attached to port excess gas overboard. A fitting with a short section of copper tubing is provided. This is connected to a section of 1/4" aluminum tubing through a section of semi-ridgid plastic tubing. The aluminum tubing is bent to conform to the engine mount and then fed through the under side of fuselage skin.
