Brief Description: Mounted prop governor to engine
Mounted the constant speed prop governor to the back of the engine. This took a little research to get right. The assembly instuctions provided by Van's don't quite work. You need to mount the control cable clevis with the bolt coming from the opposite direction as to what is described in the instructions.
