Brief Description: Added braces to ELT panel, ran wires
The ELT is much to heavy to for the side panel to support without significant deflection. Cutting slots into the front and back flanges to allow additional rudder cable clearance has made this panel subject to lateral deflection. I decied to add braces made out of short pieces of the formed material used for upper longerons. When clecoed in, this eliminated the deflection problem. I alss ran the wires from the ELT forward through the right side flexible conduit.
