Brief Description: Finished tank selector, fuel pump install
Finished up bending the rigid tubing for the fuel pump and selector. Figuring out how to bend the tubing took many tries with a lot of scrap. End result looks good and has no kinks. All the tubing near the fittings is straight. Ran out of tubing to go between the fuel fuel pump and the firewall. I have not decided where to run the fuel line through the firewall. There will be no gascolator in front of the firewall.
