Started work on the high pressure fuel pump. The first step was to bend the tubes connecting the pump to the filter. Cut holes in the center floor cover and fuel selector cover to fit the fuel pump mounting bracket. Drilled holes for the platenuts holding these together. Built up the fuel pump cover pieces.
