Brief Description: Installed left landing gear mount, right fuel line
Installed the left landing gear mount Spent nearly an hour grinding the holes open to clear the wing bolts. Bolted the mount to the ailerons and fuselage sides. I then ran the ridged fuel line between the center location, thorugh the bushings, and the outside of the fuselage. This reqiured slow coaxing of the line through the right gear mount. Straightened the tube and bent the tube upward toward the fuel selector. At this point, I realized its time to
