Brief Description: Attach seat adjusters to aft seat floors
Cut six pieces of hinge to length and trimmed off the appropriate hinge tabs in the center of each. Marked and drilled the hinges as called out in the print. Positioned the hinges on the aft seat floor plates and match drilled the plates to the hinges. Clecoed the aft floor plates with hinges installed into the center secition.
