Put together a manometer using a 12 ft piece of plastic tubing and the needed connector and plug for the AN fittings. Put water in the tube. Sealed off all the openings. Blew air into the drain fitting to generate about 3 ft of water pressure in the tank. Unfortuneately, the tank has a leak. Using soapy water, I found the leak in the capacitive sensor connector.
