Drilled out the bellcrank brass bushing with a .250" reamer. Held the bushing in a block of wood that was clamped to the drill press. This worked out pretty well. Attached the bellcrank to the brackets mounted to the spar. Ready to assemble the ailerons to the wing and set the pushrod lengths.
