Took off half the day to spray paint all the remaining parts. The vertical spraying went reasonably well after I figured out that I had to attach a weight to the bottom of the parts to keep them from blowing away from the gun. Got a few small sags, but very little dust or overspray on the finish. Turned out better overall then the first set of parts.For the parts on the table, I discovered that I need a better way to hold small parts down. The wing stiffeners were blown by the gun. I need to keep this in mind in the future when I prepare to spray parts.Also, the cold finally affected the drying on the small parts. I turned some of them over in order to paint the other side a little to soon. They ended up sticking to the blocks a some points. This was only on the interior surfaces, so it won't be noticed on the finished work.
