Brief Description: Prime front spars and nutplates
Decided to use the same epoxy primer to spot prime the leading edge and to prime the nutplates. This may be overkill, but Alexander Tech Center pimed the nutplates, so I decided to as well. Basially stacked up the nutplates on a rod in order to spray the tabs, but avoid getting paint on the threads. This worked very well.
