Brief Description: Mounted compass to center strut
Decided to mount the magnetic compass just about the panel glare shield. Routed the panel light wires through a hole in the support tube down behind the panel. This will be tied into the panel light circuit before the dimmer. The light is relatively small so that it can be run at full intensity all the time.
