Installed the aluminum vents under the instrument panel. The left vent has a panel underneath it for mounting control cables for oil temp, ventilation, and parking brake. I have not fabricated a similar panel for the right vent. This needs to be done. Installed the hose between the air vents and the NACA vents on the side of the cabin. Secured the hose with hose on each end with hose clamps.
