Brief Description: Installed Dynon pitot in left wing
Uninstalled the Gretz pitot tube. Added another bracket to mount the pitot and aoa lines. Decided to mount this bracket using screws to nutplates in the spar web. Mounted the bracket so that there was enough tubing to connect the lines into the tubing. Unfortuneately this turned out to be a little high preventing the pitot extension tub from being removed from the wing. Hopefully, this will not be a problem during painting.
