Kay and I rivetted the top skin to the cabin today. In order to set the rivets above the Garmin stack, I had to completely remove the component frames. I was then able to set all the above the instrument panel. I worked my way forward to first to do the center rib and then the two outer ribs. Finally, I had Kay help me with the edges. The most outer, aft rivets had to be set conventionally with a rivet gun.This has been a long time coming, but it sure is good to have it installed!!!
