The GNS 430 has seperate inputs for the nav antenna and the glideslop antenna. After consulting vansairforce, I decided to use a diplexor on the nav antenna lead to service both inputs. I mounted the diplexor on the center rib and ran the antenana leads as required. Picture 3 shows a bracket that I added for dressing antenna leads on the firewall.
